Download
Introduction
This chapter introduces the features andĀ possibilitiesĀ of the firmware.
Installation
You don’t need to be a programmer to get this firmware installed yourself. A detailed step-by-step tutorial leads you through the process of installation. Simply follow the instructions and replace the configuration values by the one matching your printer. At the end you have your customized version made solely for your special printer.
First Steps
Check if have done everything right.
Troubleshooting
The result is not as expected? Maybe this chapter can help you.
Special Documentations
- Repetier G-Code Plugin for Inskscape
- Dead-time temperature control
- Z-Probing / Auto leveling
- Guide for mixing extruder setup.
